error -609 in unattanded installation
DB_9942691
7-Bedrock
hi @all,
we're trying to create an unattended installation package for creo 7.0.4.0,
but after it run on first installation without problems, on second run setup.exe it brings return code -609 (although it was uninstalled before properly)
do you need further informations and which?
machines are windows 10 1909.
thanks and regards
Dom
got it now! in my case, this return code -609 was caused by a service which wasn't uninstalled in automated way before:
"PTC Creo 7 Platform Services" wasn't uninstalled correctly and prevented a new installation.
regards
Dom
@DB_9942691 wrote:
hi @all,
thanks and regards
Dom
1.] please describe, what is unattended installation ... is it mentioned in Installation and Administration Guide ?
2.] ask PTC Support, too
Martin Hanák
hi, thanks for the reply!
with an unattanded installation I meant call the setup.exe and add via parameters the path to the xml files which were created with a manual installation with the desired settings
like c:\ccmcache\xx\setup.exe -xmlall c:\ccmcache\xx\xml
this is one of the options in installation and administration guide... page 140 and following, especially page 145
good idea, i didn't thought about creating a support case... i will check how to, thank you
but i'll let this topic open, if somebody had the same problem or an solution... i will also add a note, if i got an answer by support
regards
Dom
"Open a Support Case": https://www.ptc.com/en/support/case-logger
regards
Dom
