feed color
DogariuSebastia
feed color
Does anyone know if it is possible to change the feed color in config.pro? I want to have the same colors for every new part I want to manufacture.
Sebastian,
I know you can change the feed color, but I don't see any config parameters to make them permanent.
Haven't tested it out, but you can probably use a mapkey to do this so that you can just hit one key each time you start a new model and it will go throught the color changes that you want
Another way to do this is to create a Manufacturing template file that includes your color changes and what ever else special you want every time.
