how to update model
EricHuffman
2-Explorer
how to update model
Gurus,
I feel like a rookie asking this question but it is not obvious to me. I'm working in CREO and decide to update a model. So, I checked it out, made my mods, and saved but did not check it back in. Now I have decided I didn't like that change so I want to revert back. Previously, I could just do a undo-checkout then an update and my model would revert back. How do you do this now?
CREO 2.0 m040
Windchill 10.0 m030
Eric
Just undo/cancel check out.
If it doesn't revert back, there may be some preferences that need to change. IIRC there is one that dictates what happens when a check out is cancelled; either keep the modifications or not.
StephenW
(To:EricHuffman)
You have to undo your check out and in the window for the undo checkout, select the file and change the reuse to download.
[cid:image001.png@01CF386D.EF3BFB30]
[cid:image002.png@01CF386D.EF3BFB30]
Thanks for the help but is there any way to do this all in the CREO window.
Eric
This works very well so I guess I will use this method from now on.
Thanks Steve and all others who replied.
Eric
llie
(To:EricHuffman)
Eric,
Also check to see if your company uses workspace frames.
Check into what Donald wrote about the Undo Checkout options.
As a last resort, you could also just delete it from your workspace and check it back out.
Lance Lie
