license downgrade
KA_10353348
3-Newcomer
license downgrade
Hi All,
I would like to know if it is possible for users to use downgraded versions of software in the current subscription licensing model or is it something that PTC restricts somehow?
@KA_10353348 wrote:
Hi All,
if you buy Creo Parametric Subscription license now you will receive license file containing Creo Parametric 9.0 license. The license enables you to install an run any Creo Parametric release starting from 2.0 to 9.0 and also ProE Wildfire.
Martin Hanák
5 REPLIES 5
@KA_10353348 wrote:
Hi All,
Martin Hanák
Thank you @MartinHanak
Would it also be similar for ArborText and Windchill?
I hope the situation is similar for ArborText and Windchill ... unfortunately I am not 100% sure.
Martin Hanák
If I remember correctly, Arbortext licenses work the same way (you get one license for latest available version and it allows for running older versions as well). Windchill licenses also allow you to run older versions of the software, they are mostly for establishing which users can connect to the system.
BenLoosli
(To:KA_10353348)
Windchill licensing is a bit more complex.
Prior to Windchill 11.1, there was no license checking with Windchill.
After 11.1, you may need multiple licenses to accomplish your tasks.
All versions since 11.1 should work with the generated licenses key.
