maximum windows config option..
PAULKORENKIEWIC
Quickie... What is the config.pro option that controls the window size
that Pro/E opens with?
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
Paul,
You'll want to be setting windows_scale and reserved_menu_space
Iain
Paul,
I'm not familiar with the two options that Iain mentioned, but setting open_window_maximized to yes will maximize the Pro/E session when you open Pro/E. All subsequent windows opened after that will also open maximized.
Just in case this is the one you were asking about.
Jeff Horacek
Sr. Designer
[cid:image001.jpg@01CBAE7A.9CAB3460]
STERIS Corporation
5960 Heisley Rd.
Mentor, OH 44060
(440)392-7721 P
(440)392-8954 F
