modify default value in BOM baloon
Yunny(Yunko_KR)
3-Visitor
I am using Creo Parametric Release 8.0 and Datecode8.0.6.0
Hello, and good morning.
I have sent a same topic.. But it looks lost. I send you again.
when I make the BOM baloon. I want to change the default value rpt.index to the other one in table properties.
anyway I want to show you the picture.
@Yunny(Yunko_KR) wrote:
I can modify that click the select and change... if I can, I want to know set it by default value..
Anyway thank you for interest of my question.
1.]
You cannot set asm.mbr.part_name as default value used for creation of any new repeat region.
2.]
You can create repeat region, set asm.mbr.part_name as BOM value, save table into .tbl file and import this file into new drawing when you need it.
3.]
You can create drawing format -OR- drawing template, place the needed repeat region table into it and use this format/template when new drawing is created.
Martin Hanák
please publish a picture explaining your request.
Martin Hanák
1.]
2.]
3.]
Martin Hanák
