The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Something has changed. I have no idea what. Hope y'all can help.
I try to live by the admonition :"save early and save often"
When I hide a layer or component or assembly, it remains hidden when I re-open the file. This used to not be the case -
I swear, I have NEVER saved layer states. Really. NEVER, EVER.
I renamed my config.pro file (old_config.pro) so the stock config.pro file is loaded (I hope).
The behavior persists.
Any ideas? What have I done?
Creo 2.0 M010
Thanks!
Resolution was (you're gonna love this):
1.burn the config.pro files
that didn't work - hidden models were still persistently and perversely hidden
2. re-install creo (what fun! only took the whole afternoon! another day ***poof!***)
This seemed to chase the goblilns away. Or maybe it was the phase of the moon. Or sunspots.
Anyway, it's back to what passes for normal now.
It depends. How long have you been using PTC CAD?
PTC changed the behavior at least as far back as Wildfire. Before that Hide was a transient, unsaveable change. Then PTC merged it into layer management and made the Hidden layer permanently, well, Hidden. This meant that no Save Layer Status was required, but I think it stinks, as there is some benefit to an unsaveable transient visibility status. Like not ever having to worry about making an accidently state change that affects drawings and upper level assemblies.
I guess create a mapkey that performs Unhide All and then Saves.
Six months. And if I can't fix this, maybe not much more .
How can I save this mess so that when I (or someone else) opens it, the models aren't hidden?
You can always delete those layers and unhide everything you expect to see. Then save the layer status.
That's a dffferent problem - same release, changed behavior?
Use Info on the components and see what layers they are on. Then check the layers and see if the components are placed there by rule.Hide/Unhide in the model tree should add and remove them from the Hidden layer, if that's the layer they are on.
If that's not it, it may be a problem internal to the model that might be cleared up by simply opening it with a later version of Creo.
I for one have resorted to always start with an "empty" part or assembly. No auto-layers and frilly behavior.
Things do still hide on their own when I use a sketch for an extrude, for instance; or I create a datum on the fly (within a feature) and it then hides itself once the feature is complete.
Layer states that I specifically change always reverts if I forget to save the status.
Jim,
Creo 2.0 M010 is VERY OLD maintenance release and it is "unfinished". I suggest you to move forward and use more recent maintenance release. Current maintenance release is M110.
Martin Hanak
Have you tried right clicking on "Layers"and going to "Reset Status", just to make sure it hasn't been saved by some default magic that PTC has invented?
Hi Jim,
Let us know if this is still an issue or if you resolved it. Also please mark one of the posts as "Correct Answer" if applicable. Otherwise, mark your own response as correct if you figured it out on your own.
If this is still an issue we should confirm it is something being done by your machine or if another user is making the change and saving the status.
If Hidden status upon retrieval, there probably something in your config.pro. Perhaps your administrator changed the start-up script and adds a config option
At least you didn't have to reformat your drive
Thanks for posting the solution!
You realize, from now on, every question you bring could be answered 'Did you reinstall first? '
With any luck that won't be the answer you need. Good to see it sorted out. Is it the same version?
