Loading default color.map in CREO 2
I am on Creo 2, build 030 and trying to get my color.map to load. I have the files color.map and color.dmt in the D:\cad\creo directory. My personal config.pro contains "pro_colormap_path D:\cad\creo".Upon opening Creo and looking at all options in the cofiguration editor I see two lines in order:
pro_colormap_path $PRO_LOCAL_DRIVE\cad\creo
I believe the first line is the "corporate" config.pro and the second is my personal one.
Unfortunately, when I go into RENDER and look at My Appearance, I do NOT see my color.map. I have to manually load this file each session. What am I doing wrong?
thanks in advance...
