i have a problem with plotting A2 vertical - A1 vertical and A0 Vertical on a hp610 plotter.
The system doesn't rotate the vertical sheet.
Do i have to do this in the .pcf file or with the printer driver settings?
help!
thx
Stijn,
I guess you can try to replace for example A1 paper with Variable paper and switch Width and Length values (use width and length values valid for A1 size). It seems to me that I used this trick a long time ago.
Martin Hanak
Stijn,
Martin Hanak
