Creo 3 has a number of new annoyances. Two things which it has been doing a lot today are:
1. Turning solid extrudes into cuts because some algorithm determines that it looks like the feature being made might eventually be a cut.
2. Popping up a notification window to ask me to check that the feature turned out how I wanted. As though I wouldn't do that anyway.
Who knows which config.pro options turn off this rubbish?
The first one would be auto_add_remove in config.pro (set by default to yes); as for the second one, I don't remember such notification, could you post a screenshot?
Thanks, that's one down.
Here's a screenshot of the other one:
