hello
i have a assembly and when i modify ultimate part of saving fille i have a error and i want to return to part save 1 of part
for nut.prt1
nut.prt2
nut.prt3
nut.prt4 last fille saved and i want to return to inital part (nut.prt1) how make this ?
tks in advance
if nut.prt.4 is last file saved and you want to use nut.prt.1 in your assembly,
then:
MH
Hello Bogdan,
When you open a file you ask to see all versions
saved in the menu bar and you should see the. prt.1,. prt.2,...
Kind regards.
Denis
then:
MH
All good ideas, here's the simple method I use.
You can do the same thing if you wanted to go back to any version that exists on disk.
Hello bogdan ,
you can try this way also .close the window and erase in session , then go back to the Folder were you saved assembly and part . Then delete Creo version file
nut.prt2 ,nut.prt3 and nut.prt4 ,Later when you open the assembly automatically it will take the left out version of nut.prt1 ie .1 in from the saved folder.
Regards
