Dear Community
The license file "license.dat" includes licenses for several creo tools not included in the creo student version I used beforehand.
The problem is:
After having declared the path, the status changed to Starting... (see image below) however afterwards didn't (even after hours) switch to Succeed.
Among others I also crated a text file "license.txt" and reinstalled creo several times (deleting all related data).
Is there any literature related to this issue. Most contend (like manuals) is not availaible for student users.
Does anyone have an idea?
Thanks in advance!
Stephan
to be able to tell you what is going on I need to see the contents of your license file.
MH
Here you are
I hope these are the contents you referred to.
I intentionally changed the Host ID and the Contract to "..."
#**************************************** Summary Table *******************************************************
# PTC Host ...
#FeatureName Qty Product Release Type Expiration Contract
#280 1 Creo Elements/View Massive Assembly Opti Creo 4.0 Flt Opt 01-jan-2019 ...
#281 1 Creo Elements/View Validate for Model Ba Creo 4.0 Flt Opt 01-jan-2019 ...
#319 1 Creo Elements/View Interference Creo 4.0 Flt Opt 01-jan-2019 ...
#320 1 Creo Elements/View Animation Creo 4.0 Flt Opt 01-jan-2019 ...
#157 1 Pro/MECHANICA Fatigue Advisor UI Module Creo 4.0 Flt Opt 01-jan-2019 ...
#161 1 Pro/MECHANICA Fatigue Advisor Engine Mod Creo 4.0 Flt Opt 01-jan-2019 ...
#211 1 Creo Simulation Advanced UI (formerly Pr Creo 4.0 Flt Opt 01-jan-2019 ...
#212 1 Creo Simulation Advanced ENG (formerly P Creo 4.0 Flt Opt 01-jan-2019 ...
#89 1 Pro/MECHANICA CUSTOM LOADS Creo 4.0 Flt Opt 01-jan-2019 ...
# 1 Creo Elements/Direct 2D Library (formerl 18.1 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Drafting (formerly 20.0 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct 3D PDF Converter (f 18.1 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct XVL Converter (form 18.1 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct eDrawings Professio 18.1 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Advanced Design (fo 18.1 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Part Library (forme 18.1 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Mold Base (formerly 18.1 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Portable License En 18.1 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Modeling (also enab 20.0 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Sheet Metal (former 20.0 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Finite Element Anal 20.0 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Surfacing (formerly 20.0 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Drawing Manager (fo 18.1 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct BOM Editor (formerl 18.1 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Task Agent (formerl 18.1 Flt Lic 01-jan-2019 ...
# 1 Creo Elements/Direct Web Client (formerl 18.1 Flt Lic 01-jan-2019 v
# 1 Creo Elements/Direct Model Manager (form 20.0 Flt Lic 01-jan-2019 ...
#CREODMA_EDUC1 1 Creo Direct Modeling Education Creo 4.0 Flt Lic 01-jan-2019 ...
#PVMCADPRO 1 Creo View MCAD Educational Creo 4.0 Flt Lic 01-jan-2019 ...
#PVPRO 1 Creo View Base Educational Creo 4.0 Flt Lic 01-jan-2019 ...
#PROE_Educ1 1 University Plus Site License Creo 4.0 Flt Lic 01-jan-2019 ...
#ILINK_CLIENT_License 1 Pro/INTRALINK Multi Site - License 11.0 Flt Lic 01-jan-2019 ...
#CREOILLUS_STANDARD 1 Creo Illustrate Education Creo 4.0 Flt Lic 01-jan-2019 ...
#CREOLAY_Educ 1 Creo Layout Educational Creo 4.0 Flt Lic 01-jan-2019 ...
#MECBASICENG_License 1 Creo Simulation Basic ENG (formerly Pro/ Creo 4.0 Flt Lic 01-jan-2019 ...
#MECBASICUI_License 1 Creo Simulation Basic UI (formerly Pro/M Creo 4.0 Flt Lic 01-jan-2019 ...
#CREOSCHEM_License 1 Creo Schematics (formerly Routed Systems Creo 4.0 Flt Lic 01-jan-2019 ...
# 1 University Plus eLearning Library 000 Flt Lic 01-jan-2019 ...
# 1 Pro/FICIENCY Library 000 Flt Lic 01-jan-2019 ...
#VERICUT_License 1 Vericut Creo 4.0 Flt Lic 01-jan-2019 ...
Thank you for your answer!
Stephan
Stephan,
Check if there is any existing PTC License server, if any, uninstall that. and try reinstallation
all your licenses are floating according to information you provided (lines beginning with # are comments).
The license file must contain two lines similar to following ones
SERVER __HOSTNAME__ PTC_HOSTID=00-11-22-33-44-55 7788
DAEMON ptc_d __PTCD_PATH__
Instead of 00-11-22-33-44-55 SERVER line must contain MAC address of network card installed in your computer. This card must "alive", this means you have to see it in ipconfig /all command output.
Note: Follow Mahesh Sharma advice and check if FLEXnet uis already installed on your computer. Open list of installed programs and check if you can see PTC License Server... item -OR- FLEXnet Admin Version... item. Unistall the item and repeat installation procedure.
MH
Hallo,
I haven't got a program called FLEXnet and I can't install it either (I am using a student version download file/ it doesn't seem like there is a way to obtain it from there).
The file license.dat is an academic license which I got from my school and I wanted to use for my home-computer for education purposes.
Is it necessary to create a license service (I do not use more than one computer)? Is Node-Locked Licensing not possible?
The email which transferred the license file stated the following:
---- Installation Instructions Node-Locked Licenses ----
Most PTC FlexNet enabled products can also utilize Node-Locked license files.
Either of the 2 license licenses file should be saved to the local machine as either license.txt or license.dat.
Example: c:\ptc\license.dat
Furthermore the lines
are included in my license file. And my Mac adress is correct.
Thank you very much for your replys.
Stephan
if I understand you well, your license file contains SERVER and DAEMON lines. This means you must install FLEXnet license manager at first.
MH
Hallo
It does the same as in my initial question: Starting...
Thank you
Stephan
it looks like FLEXnet is already running on your PC. Please open Command prompt window, launch tasklist > tasklist.txt command and upload tasklist.txt file.
MH
Here you are
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\Users\Stephan>tasklist
Image Name PID Session Name Session# Mem Usage
System Idle Process 0 Services 0 4 K
System 4 Services 0 19,152 K
smss.exe 380 Services 0 1,060 K
csrss.exe 556 Services 0 3,752 K
wininit.exe 668 Services 0 4,164 K
csrss.exe 676 Console 1 5,600 K
services.exe 740 Services 0 7,524 K
lsass.exe 748 Services 0 14,060 K
svchost.exe 848 Services 0 21,180 K
winlogon.exe 928 Console 1 11,336 K
svchost.exe 1020 Services 0 10,840 K
dwm.exe 496 Console 1 62,380 K
svchost.exe 988 Services 0 121,724 K
svchost.exe 1004 Services 0 54,356 K
svchost.exe 472 Services 0 19,732 K
svchost.exe 1160 Services 0 20,068 K
WUDFHost.exe 1196 Services 0 7,204 K
svchost.exe 1308 Services 0 28,824 K
svchost.exe 1476 Services 0 29,892 K
igfxCUIService.exe 1560 Services 0 12,224 K
NVDisplay.Container.exe 1716 Services 0 9,208 K
svchost.exe 1872 Services 0 9,112 K
nvxdsync.exe 1900 Console 1 22,792 K
svchost.exe 1932 Services 0 10,508 K
svchost.exe 1544 Services 0 12,396 K
spoolsv.exe 548 Services 0 15,468 K
AdminService.exe 2448 Services 0 6,996 K
armsvc.exe 2456 Services 0 5,404 K
AdAppMgrSvc.exe 2468 Services 0 13,848 K
chip 1-click installer.ex 2476 Services 0 19,540 K
officeclicktorun.exe 2488 Services 0 21,088 K
svchost.exe 2508 Services 0 22,344 K
ijplmsvc.exe 2520 Services 0 5,112 K
smpd-intel-4.0.3.009-x64. 2568 Services 0 5,660 K
IpOverUsbSvc.exe 2576 Services 0 11,872 K
nutsrv4.exe 2664 Services 0 5,188 K
sqlwriter.exe 2684 Services 0 6,812 K
svchost.exe 2700 Services 0 8,348 K
StreamingCore.exe 2724 Services 0 54,504 K
svchost.exe 2824 Services 0 16,872 K
TeamViewer_Service.exe 2832 Services 0 20,952 K
MsMpEng.exe 2868 Services 0 79,992 K
Memory Compression 2296 Services 0 140,672 K
NisSrv.exe 3964 Services 0 13,112 K
sihost.exe 4092 Console 1 20,324 K
svchost.exe 1408 Console 1 23,524 K
taskhostw.exe 1676 Console 1 18,016 K
PresentationFontCache.exe 4124 Services 0 20,072 K
RuntimeBroker.exe 4236 Console 1 41,976 K
explorer.exe 4308 Console 1 110,424 K
TeamViewer.exe 4316 Console 1 31,176 K
ShellExperienceHost.exe 4900 Console 1 70,168 K
SearchUI.exe 5004 Console 1 129,560 K
SearchIndexer.exe 4456 Services 0 45,152 K
igfxEM.exe 5224 Console 1 12,580 K
igfxHK.exe 5232 Console 1 7,688 K
igfxTray.exe 5256 Console 1 9,880 K
tv_w32.exe 5476 Console 1 6,196 K
tv_x64.exe 5484 Console 1 5,788 K
nvtray.exe 6108 Console 1 13,532 K
MSASCuiL.exe 5844 Console 1 10,380 K
RAVCpl64.exe 5932 Console 1 11,484 K
RAVBg64.exe 6000 Console 1 9,788 K
BJMYPRT.EXE 6072 Console 1 6,204 K
OneDrive.exe 3324 Console 1 25,524 K
CNSEMAIN.EXE 6284 Console 1 47,720 K
splwow64.exe 6376 Console 1 14,036 K
CNMNSST.exe 6428 Console 1 7,548 K
jusched.exe 6524 Console 1 6,072 K
CoreHelper.exe 7096 Console 1 7,792 K
CNSEUPDT.EXE 5092 Console 1 7,916 K
SettingSyncHost.exe 3068 Console 1 3,668 K
RemindersServer.exe 7156 Console 1 5,520 K
setup.exe 6012 Console 1 13,236 K
setup.exe 5424 Console 1 29,028 K
ApplicationFrameHost.exe 4084 Console 1 22,348 K
SystemSettings.exe 1032 Console 1 39,096 K
Time.exe 3160 Console 1 31,256 K
devenv.exe 5264 Console 1 303,348 K
VsHub.exe 7116 Console 1 43,408 K
Microsoft.VsHub.Server.Ht 2504 Console 1 125,820 K
conhost.exe 4540 Console 1 5,740 K
fontdrvhost.exe 956 Console 1 4,272 K
MpCmdRun.exe 3664 Services 0 9,432 K
StandardCollector.Service 1500 Services 0 10,812 K
Microsoft.VsHub.Server.Ht 6684 Console 1 99,236 K
conhost.exe 4404 Console 1 6,148 K
texmaker.exe 1884 Console 1 71,384 K
SystemSettingsBroker.exe 7668 Console 1 17,528 K
firefox.exe 1860 Console 1 544,516 K
dllhost.exe 8680 Console 1 10,088 K
ConsoleApplication6.exe 10220 Console 1 3,476 K
conhost.exe 9904 Console 1 8,944 K
ScriptedSandbox64.exe 7928 Console 1 64,612 K
dllhost.exe 11348 Console 1 13,472 K
AcroRd32.exe 9256 Console 1 20,216 K
AcroRd32.exe 8640 Console 1 95,316 K
RdrCEF.exe 9028 Console 1 36,668 K
RdrCEF.exe 5268 Console 1 61,172 K
RdrCEF.exe 8244 Console 1 60,108 K
vcpkgsrv.exe 8564 Console 1 42,292 K
firefox.exe 11080 Console 1 73,516 K
backgroundTaskHost.exe 12060 Console 1 17,124 K
smartscreen.exe 12072 Console 1 14,776 K
cmd.exe 7744 Console 1 2,964 K
conhost.exe 11716 Console 1 14,872 K
tasklist.exe 11844 Console 1 7,712 K
WmiPrvSE.exe 10428 Services 0 8,532 K
C:\Users\Stephan>
Thank you
I can't see any sign of presence of license manager. Maybe there is a collision between Creo setup and some of running processes (this is my guess, only). Maybe Creo setup is not able to create system service ?
MH
Thank you very much
Finally it worked after resetting my pc (Initially I wanted to prevent that)
Stephan
