"john pryal" wrote:
Hi all, does anyone out there know how to stop sketched curves automatically hiding if they are selected to drive a feature such as a revolve or extrude. It is most annoying to continually have to manually unhide a sketch in the model tree to make it visible again within the the model. Also, saving layer status does not seem to work on such curves, so every time the part is brought into session you have to go through the same procedure again. I'm sure its a config option, but can i find it, *beep* no. Thanks
