when I open the program I just see a black screen
TT_12193950
3-Newcomer
I have installed Creo Parametric 11.0 on my laptop (RTX4060 and  intel i5). now when I open the program I just see a black screen. I have already done an update of my graphic card driver, but that did not help. If anyone knows how to resolve this issue, I would be glad if you could let me know.
@TT_12193950 wrote:
I have already seen this post, but all of the suggested solutions did not help to solve my issue. 😞
please click File > Help > System Information > System Information.
Then scroll window contents until you see Creo Parametric Graphics Type:
It must be set to win32_gdi
In my case it is set to OPENGL (because my graphic card is accepted by Creo)
Martin Hanák
8 REPLIES 8
Martin Hanák
Could you tell me how to set the Graphics type to win32_gdi?
the procedure is described in https://community.ptc.com/t5/System-Administration/Black-screen-in-Creo-Parametric-Educational-Edition/td-p/956159 discussion.
Do following test:
  • open config.pro in Notepad
  • add following option at the end of the file and save the file
graphics   win32_gdi
  • start Creo
Martin Hanák
when i open the config.pro file and add the "graphics   win32_gdi" i click save but a message appear saying that i cant modify the files and i have to notify a moderator. im using my personal computer i dont understand why i cant modify my own files...
StephenW
(To:AS_12985683)
@AS_12985683 Likely the folder you are trying to modify the config.pro file is set to read only. If it is a personal computer, you can probably change that folder setting
Is this permanent solution? because a person commented in community page this method will degrade the creo performance.
Even though I tried updating drive facing same issue.
