2330
Views
| I have my custom java packages, I have to import these packages in js
file which is located at integ...
2330
Views
1495
Views
| We at TRW receive quite a few data from our customers in xml format. I
would prefer to push this inf...
1495
Views
1812
Views
| Hello, Is there a way to delete or deactivate a test step in Integrity
10 on GUI or eith CLI? In Wor...
1812
Views
by
byoung
1 Reply
1027
Views
| I have legacy protocols that loop on the test procedure (that is,
several test steps (as a group) ar...
1 Reply
1027
Views
3401
Views
| I am able to import a word document (test specification document) in to
PTC Integrity Test managemen...
3401
Views
2193
Views
| Hi... I have a script that executes the command: "aa user --groups
myuserid" but I'm not able to ext...
2193
Views
1 Reply
1097
Views
| Currently there is an understanding that a trace/link between two data
objects can be created throug...
1 Reply
1097
Views
1 Reply
1093
Views
| Within the Requirements Management module, whenimporting requirements
into a project, will PTC do te...
1 Reply
1093
Views
1 Reply
1136
Views
| Can I edit image files within Integrity?
1 Reply
1136
Views
1983
Views
| How does Source Integrity indentify that a member has been modified and
can be checked-in? As per my...
1983
Views
1998
Views
| In Integrity presentation templates I insert an image URL to an image on
the server (correct locatio...
1998
Views
by
thussong
628
Views
| Is there a guide or any other references that could help explain the
functional differences between ...
628
Views
1793
Views
| Hi, Is there any API function to write data on local file. Ex: I want to
write 'Hello Word' in the f...
1793
Views
2270
Views
| I have a project that was moved into another project using Integrity
client. After the move, our aut...
2270
Views
1392
Views
| Hi, I want to write a Python-Program for monitoring the PTC Integrity
server. Since i haven't found ...
1392
Views
4629
Views
| Is there a way to export reports in Integrity, Just copying the report
seems to work for some of the...
4629
Views
Hi @all, my users want to see which calendarweek it is, if they set a
special date in an integrity-i...
819
Views
4649
Views
| I am creating a story via the API im createissue --user=nshaikh
--port=7001 --hostname=integrity.ptc...
4649
Views
by
rteifke
3385
Views
| What syntax is needed using the C# API for the following Command LIne
Interface [tm editresult --fie...
3385
Views
1427
Views
| Dear Community, Within an hierarchical tree of Items we want to make
sure, that we do not have any t...
1427
Views
2761
Views
| Does anyone have any idea what I am doing wrong? I have installed the
server and collector on a Wind...
2761
Views
2409
Views
| I have to migrate from clearcase to MKS ( PTC ) with full revision
history , could anyone guide me a...
2409
Views
1914
Views
| As part of our help desk area, we want to display current ticket
information charts that update peri...
1914
Views
2058
Views
| Does anyone have a link to where I can download the latest MS Project
Integration for Integrity?
2058
Views
2166
Views
| Hey there, i tried a lot recieving all attachments of an item over the
SAOP API, but i wasn't succes...
2166
Views
1 Reply
1969
Views
| Having just installed the Implementer plugin to RDi 9.1, ALL the "user
filters" ever created by a us...
1 Reply
1969
Views
by
dakers
2362
Views
| Extended Integrity LM family. Those of you that import document from
Microsoft Word to PTC Integrity...
2362
Views
3323
Views
| Not able to find ReqIf import option in PTC Integrity client. Looking at
these links, it looks like ...
3323
Views
2443
Views
| Is there a way of creating the Item Type "Tag" in PTC Integrity using
CLI?
2443
Views
by
DanR.
1481
Views
| We recently upgraded from MKS Integrity 2009 SP7 (AIX) to PTC Integrity
10.6 (AIX). The upgrade was ...
1481
Views
| Subject | Author |
