Hi @TanmeyTWX ,
I'm pretty new to thingworx, I came across this post while searching for the ptc-grid edit, previously by using the legacy grid widget it was pretty easy to use the grid, after upgrading to the new widget finding very much difficult to get the edit cell values(text, number, boolean or any type) I'm able to get only single row from the EditedData property of the ptc-grid.
If possible can you put your listings to know how you have achieved the edit options.
Thank You,
Balu
I came accross similar difficulty to have every single row, that I edited, to list to another Grid (just to check what was edited), but this is for the new Grid widget (in 9.3) which is themable,
Hope it helps a bit.
Enable the following in grid properties,
You able to see the check boxes in the grid and edit button also. For more.
Hi Balaji,
You can try this way.
