An installation of PTC Creo View is required in order to use this Widget.
ydai
Hi all,
I install Creo View Express 4.1 and ThingWorx 7.1.2-b6. I import the Creo View Widget into ThingWorx. But when I view the mashup, the browser reports me an error: An installation of PTC Creo View is required in order to use this Widget.
How can I solve this problem? Thanks a lot.
7 REPLIES 7
liliu
(To:ydai)
Hi Yijun,
I used to use Creo View widget before. As I know, you need to install Creo view on your PC and creo view  plug-in into your browser so that your browser can display 3D image.
Best Regards,
Lily
ydai
(To:liliu)
Where can I download the creo view plug-in for my browser?
liliu
(To:ydai)
Hi Yijun,
I consult with Creo View engineer, it should be Creo View Clients.
Best Regards,
Lily
I am also trying to run CreoView Widget with Navigate custom apps .
Really a CreoView (lite) must be installed. This step helps me on the server, however on my client PC this step does not help.
I run apps on Server with InternetExplorer 11. When I use Mozilla firefox, I get the "An installation of PTC Creo View is required in order to use this Widget" error mesage.
So installation of CreoView is mandatory, but not sufficient request.
Premek
I also try to run apps on Server with IE 11, but it shows me a piece of white. It shows nothing. No error, no warning...  Would you mind to give me some ideas? Thanks a lot.
and I use the Creo View Express, I can see my part.
ykuo
(To:ydai)
Hi ydai,
Did you find any solution to fix up "shows me a piece of white. It shows nothing. No error, no warning.". Because I also get the same issue you mentioned before. Thanks.
xchen
18-Opal
(To:ykuo)
Hi ykuo,
If you could found something like following logs in your Windchill MethodServer logs, you can try to add your client host name/IP to wt.auth.trustedHosts in wt.properties file.
ERROR [ajp-nio-127.0.0.1-8010-exec-5] wt.httpgw.filter.TrustedAuthFilter - TrustedAuthFilter: Attempt to set effective user to 'Administrator' from untrusted host 'XXX.XXX.XXX.XXX'
