6-Contributor
July 20, 2018
Cannot Import 'Gantt Chart Widget' extension into Thingworx 7.4.11
  • July 20, 2018
  • 2 replies
  • 1386 views
I'm trying to import 'Gantt Chart Widget' extension and I get the following error:
[context: Extension Exception]
[message: Error parsing /ThingworxStorage/extensions/temp/GanttChartExtension_v1_126a19f6-1311-4d2b->b121-32621e99865c/GanttChartExtension_v1/Entities/DataShapes/GanttChartData.xml: (9, 15): cvc-complex-type.3.2.2: Attribute 'universal' is not allowed to appear in element 'Entities'.]
Any help is appreciated.
Thanks in advance,
Nakaya
Best answer by vxavier
This Gantt Chart is not workink properly.
You will have to enter in the Gantt Chart Files and delete the Universal property in each .xml file inside "Entities".
After that this entities just will work as a guide, neither will work properly. You will have to create a new data shape, data table and new mashup to test the Gantt Chart. This worked for me, hope it works for you too.
This was exactly what I have done, attached is the zip file that worked for me.
Cheers,
Vinícius.
vxavier5-Regular MemberAnswer
Cheers,
Vinícius.
knakaya6-ContributorAuthor
6-Contributor
July 23, 2018
The file you attached worked very well!
Thank you for your help.
Nakaya
