I installed ThingWorx Analytics Server 8.2.1 (AnalyticsServer Thing was created) and trying to install Analytics Extension 8.2.1.
After importing and configure (run configuration service, add TW_ML_Session_Variable) the extension in Foundation I am unable to configure communication settings in Analytics Builder.
The Analytics Thing can be selected but the connection is unsuccessful (logged in as Administrator) . Thingworx Foundation and Analytics both are running (on same machine).
Windows 10 pro
Thingworx 8.2.1
thank you
Hi, I think I've seen similar problems before, please try to check with this article
Hi, Was your ML entity showing isconnected= true ? Did you find any logs from TWX or TWA side about it?
thank you for your reply.
Entity is showing isconnected=true
and I get following Error in logs:
[context: com.thingworx.webservices.context.HttpExecutionContext@1afc3e31][message: Execution error in service script [GetDatasetsAMS] :: java.net.ConnectException: Connection timed out: connect]
please see attachment
Thank you
thank you I will try that and let you know.
But I tried to reinstall the Extension unfortunately I can not delete thingworx_Analytics_Builder_Extension.
This is a known issue for the version 8.1 and should be fixed in the version 8.2.1, but still cant delete it.
Extension Package deletion failed: Unable to Invoke Service DeleteExtensionPackage on PlatformSubsystem : Cannot delete ExtensionPackage [ThingWorx_Analytics_Builder_Extension] because the following Extension Entities are still in use: [entity: AnalyticsServerRuntime, used-by: TempAnalyticsServerRuntimeInstance AnalyticsServerRuntimeInstance ][entity: AnalyticsServerFilters, used-by: AnalyticsServerFiltersInstance ]
Thanks, your solution worked.
You're welcome
