Hi Team,
Suppose I have a tree widget with network structure has been binded over it.
Autoselectfirstrow property of tree widget will provide first node to be as selected on load of mashup.
But what I want is node of tree to be selected on load of mashup lies anywhere in middle instead of root node.
Could anybody help me with the logic pls.
My Thingworx version is 8.3
Thanks in advance.
Use Tree grid Advanced. It has the selected rows as bindable input field.
@ranjank , Try writing a service which returns me you child of first node(2nd level) and bind that data to selected label and value.
Hi @ranjank.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others on the community.
--Sharon
Hi @ranjank.
I have marked the solution for this post. If you disagree with my choice, please let me know.
--Sharon
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
