I'm looking for services that will return me a string in the current user's language from a token. I looked in the snippets but couldn't find anything.
For example, one of the things I want to do is return an infotable where one of the parameters is the day of the week (i.e. Sunday, Monday...), I would like the service to translate the string before returning the infotable.
I have already created the tokens in the localisation tables.
Thanks.
Hi Kieron, there's runtime service available for you to fetch the token and its values. You can check them under Resources > RuntimeLocalizationFunctions
Feel free to correct me if this isn't what you are looking for.
Hi Sushant, thanks for the info, apologies for the late reply,
K
No worries Kieron, glad it helped.
