Hi Everyone,
Here i have one question consider an scenario where i have set value of a thing property on button click event by login with one user account (i.e. admin user) .... and then accessing same thingworx runtime link with different user (i.e. admin_1) in that case will i get update value of that things property or just because i login with different user i need to set value again to that things property once again ?
If you have any idea about how things property behavior could you please share with me.....
Thanks in advance,
Once you updated the property value on click of button pressed by any user , that data will get updated in database. All other users will see the updated value of property not the previous value.
Hi @RockLala.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
