CSV Parser Help
SOLVED
Newbie
CSV Parser Help
So, I am running 6.0 and am trying to parse a CSV file.  I have downloaded the CSV Parser Extension and have boiled down the code to the bare minimum and haven't been able to get it to work.
In fact, I have a very simple test and my results are the same as when I use the GetCSVFile Method.  Here below I am using a very simple example and the result is that I only get the very first column and not the second column. I am certain I am doing something wrong but I haven't been able to locate the documentation for the extension.  I have looked through the forum and found links but they are dead links.
Can someone help with getting the Description column populated?
Thanks in advance
var params = {
  columnMappings: "Tagname; Description;" /* STRING */,
  hasHeader: "false" /* BOOLEAN */,
  longitudeField: undefined /* NUMBER */,
  dateFormat: undefined /* STRING */,
  latitudeField: undefined /* NUMBER */,
  fieldDelimiter: undefined /* STRING */,
  stringDelimiter: undefined /* STRING */,
  content: '"XV101,Valve Input"' /* STRING */,
  dataShape: "PES_Tags" /* DATASHAPENAME */
// result: INFOTABLE
var result = Resources["CSVParserFunctions"].ParseCSVFile(params);
1 ACCEPTED SOLUTION
Re: CSV Parser Help
Few things that may cause it:
  • ColumnMappings
    • Remove spaces between columns ( you have a space after the ";" )
    • Remove the last ";"
  • hasHeader
    • change "true" for true
  • FieldDelimiter
  • StringDelimiter
  • content
    • I've never parsed a string content, I parse csv files from file repositories
    • But on your case, you are opening and closing a " on your content, you should not, at least for all the row, you can for every String column
    • When you parse CSV files you need a blank line at the end, maybe it's the case with content, then you will need to add at the end \n
  • dataShape, it should exist.
29 REPLIES 29
Re: CSV Parser Help
  • ColumnMappings
  • hasHeader
  • FieldDelimiter
  • StringDelimiter
  • content
Re: CSV Parser Help
Hi Jeff,
Here is an example per the test data you provided and it works on my Thingworx 7.0.0-b479:
var params = {
    columnMappings: "Tagname;Description" /* STRING */,
    fieldDelimiter: "," /* STRING */,
    stringDelimiter: "\"" /* STRING */,
    content: "XV101,Valve Input\n" /* STRING */,
Hope this helps,
Br,
Anna
Re: CSV Parser Help
Thanks both of you!!!! My issue was the space between the columnMappings... I appreciate it.
Re: CSV Parser Help
Hi.
If i am having a column which data type is date time means, how to parse in thingworx?
Re: CSV Parser Help
I am new to thingworx, can you help me on CSV Parser plugin, I dont know how to use this and how should i implement it.
Regards
Vikas
Highlighted
Re: CSV Parser Help
I used below script to parse CSV Data.
var params = {
path: "/"+ file /* STRING */,
columnMappings: undefined /* STRING */,
hasHeader: true /* BOOLEAN */,
fileRepository: "SystemRepository" /* THINGNAME */,
dataShape: "parseCSV" /* DATASHAPENAME */
var result = Resources["Parsley"].ParseCSV(params);   //result: INFOTABLE
file - CSV file name(eg. "data.csv")
parseCSV - Datashape Name which have all field names with "STRING" basetype.
Thanks & Regards,
Sathishkumar C.
Tags (1)
Re: CSV Parser Help
Hi Satish,
I understood the script, I dont know the way from where i should start and upload csv file to run this script?
can you plz tell me?
Re: CSV Parser Help
Use Upload widget with Mashup.
Re: CSV Parser Help
Thanks Satish for prompt reply.
so, i have to follow following steps?
1) create datashapre
2) upload widget
3) create service with provided code
If Am i right? there is otherway to import csv directly without creating Mashup.
Regards
Vikas
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
