CSV Parser Help
SOLVED
Highlighted
Re: CSV Parser Help
Yeah. looks good.
Or you can put your CSV file in "C:\ThingworxStorage\repository\SystemRepository" path and use file name to run a script.
Re: CSV Parser Help
Hi Satish,
I am working on IIOT project with CNC Machine, where i am getting contineous data, so is there any way to calculate data run time or on spacific time interval? So that i can calculate OEE, Temperatures after every hour, Performance, Operating time after intervals.
I am not getting more useful informations on this. i have machine data in the form of CSV file to test above calculations, can you provide me such training references or any useful information to make calculations or javascript calculations logics
Best Regards
Vikas
Re: CSV Parser Help
How your data is communicating with Thingworx?
Re: CSV Parser Help
for now, i have collected data in CSV and want to import on thingworx to make data calculations (but i dont know how calculations should work using Query or Javascript). i will bind this data to created mashup.
Is this make sense for you?
Regards
Vikas
Re: CSV Parser Help
Hi Satish,
I have created datashape, csv file with exact column name match with datashape, now i am got confused about script! where should i write script for csv upload?
Can you help me on this plz , I have attached csv file i created.
Regards
vikas
Re: CSV Parser Help
Need not to create any script to upload a 'CSV' file.
Use "file upload widget" to upload a file.
After uploading, create a thing with new service (here only you have to write a script).
keep output as "INFOTABLE".
Re: CSV Parser Help
Yes, I created new Thing and service in it with name "getCSVData"
Here is my all code screenshot! is that right?
Regards
Vikas
Re: CSV Parser Help
put file name in double quotations (eg. "filename.csv").
Re: CSV Parser Help
i wrote above code and when i clicked on test service, it gives me attached error, I am using thingworx trial edition on my system.
plz help me on this.
Re: CSV Parser Help
After putting file name in double quote, error as follows:
Error executing service
Error executing service getCSVData. Message :: TypeError: Cannot call method "ParseCSV" of null - See Script Error Log for more details.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
