So, I am running 6.0 and am trying to parse a CSV file. I have downloaded the CSV Parser Extension and have boiled down the code to the bare minimum and haven't been able to get it to work.
In fact, I have a very simple test and my results are the same as when I use the GetCSVFile Method. Here below I am using a very simple example and the result is that I only get the very first column and not the second column. I am certain I am doing something wrong but I haven't been able to locate the documentation for the extension. I have looked through the forum and found links but they are dead links.
Can someone help with getting the Description column populated?
Thanks in advance
var params = {
columnMappings: "Tagname; Description;" /* STRING */,
hasHeader: "false" /* BOOLEAN */,
longitudeField: undefined /* NUMBER */,
dateFormat: undefined /* STRING */,
latitudeField: undefined /* NUMBER */,
fieldDelimiter: undefined /* STRING */,
stringDelimiter: undefined /* STRING */,
content: '"XV101,Valve Input"' /* STRING */,
dataShape: "PES_Tags" /* DATASHAPENAME */
// result: INFOTABLE
var result = Resources["CSVParserFunctions"].ParseCSVFile(params);
Few things that may cause it:
Hi.
If i am having a column which data type is date time means, how to parse in thingworx?
I am new to thingworx, can you help me on CSV Parser plugin, I dont know how to use this and how should i implement it.
Vikas
I used below script to parse CSV Data.
var params = {
path: "/"+ file /* STRING */,
columnMappings: undefined /* STRING */,
hasHeader: true /* BOOLEAN */,
fileRepository: "SystemRepository" /* THINGNAME */,
dataShape: "parseCSV" /* DATASHAPENAME */
var result = Resources["Parsley"].ParseCSV(params);   //result: INFOTABLE
file - CSV file name(eg. "data.csv")
parseCSV - Datashape Name which have all field names with "STRING" basetype.
Thanks & Regards,
Sathishkumar C.
Hi Satish,
I understood the script, I dont know the way from where i should start and upload csv file to run this script?
can you plz tell me?
Use Upload widget with Mashup.
Thanks Satish for prompt reply.
so, i have to follow following steps?
1) create datashapre
2) upload widget
3) create service with provided code
If Am i right? there is otherway to import csv directly without creating Mashup.
Vikas
Yeah. looks good.
Or you can put your CSV file in "C:\ThingworxStorage\repository\SystemRepository" path and use file name to run a script.
Hi Satish,
I am working on IIOT project with CNC Machine, where i am getting contineous data, so is there any way to calculate data run time or on spacific time interval? So that i can calculate OEE, Temperatures after every hour, Performance, Operating time after intervals.
I am not getting more useful informations on this. i have machine data in the form of CSV file to test above calculations, can you provide me such training references or any useful information to make calculations or javascript calculations logics
Best Regards
Vikas
How your data is communicating with Thingworx?
for now, i have collected data in CSV and want to import on thingworx to make data calculations (but i dont know how calculations should work using Query or Javascript). i will bind this data to created mashup.
Is this make sense for you?
Vikas
Hi Satish,
I have created datashape, csv file with exact column name match with datashape, now i am got confused about script! where should i write script for csv upload?
Can you help me on this plz , I have attached csv file i created.
vikas
Need not to create any script to upload a 'CSV' file.
Use "file upload widget" to upload a file.
After uploading, create a thing with new service (here only you have to write a script).
keep output as "INFOTABLE".
Yes, I created new Thing and service in it with name "getCSVData"
Here is my all code screenshot! is that right?
Vikas
put file name in double quotations (eg. "filename.csv").
i wrote above code and when i clicked on test service, it gives me attached error, I am using thingworx trial edition on my system.
plz help me on this.
After putting file name in double quote, error as follows:
Error executing service getCSVData. Message :: TypeError: Cannot call method "ParseCSV" of null - See Script Error Log for more details.
My code is:
var params = {
path: "/"+ "actual_machine_data.csv" /* STRING */,
columnMappings: "id;timestamp;tag_name;value;tag_time;tag_value" /* STRING */,
dataShape: "machineData" /* DATASHAPENAME */
result = Resources["CSVParserFunctions"].ParseCSVFile(params); //result: INFOTABLE
i got following error:
Error executing service getCSVData. Message :: Wrapped java.lang.NullPointerException - See Script Error Log for more details.
i am using thingworx 8.1 version, plz help me out....
i think column mapping can put as undefined.
I have used both way undefined and all column names too! is there any tutorials on this plz?
No, I am still researching, Can you help me on this plz?
Yes, Thank Satish. Finally i have done it and imported successfully!
Vikas
Cool.
I have csv file imported, In csv file i have 5 columns like (timestamp, tagName, condition, timestamp_value, value) so
| 1524046971797.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046975530.00 | 0 |
| 1524046972789.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046976535.00 | 0 |
| 1524046973789.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046977529.00 | 0 |
| 1524046974789.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046978333.00 | 0 |
| 1524046974804.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046979350.00 | 0 |
| 1524046975789.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046980517.00 | 3 |
| 1524046976790.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046981469.00 | 3 |
| 1524046976804.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046982449.00 | 3 |
| 1524046977789.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046983569.00 | 3 |
| 1524046978788.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046984556.00 | 3 |
| 1524046979790.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046985722.00 | 3 |
| 1524046980789.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524046986655.00 | 3
| 1524047070162.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047093717.00 | 0 |
| 1524047071162.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047094549.00 | 0 |
| 1524047072162.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047095863.00 | 0 |
| 1524047073162.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047096665.00 | 0 |
| 1524047074162.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047097686.00 | 0 |
| 1524047075162.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047098625.00 | 0 |
| 1524047091163.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047116512.00 | 3 |
| 1524047092162.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047117518.00 | 3 |
| 1524047093163.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047118781.00 | 3 |
| 1524047094162.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047119747.00 | 3 |
| 1524047095162.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047120609.00 | 3 |
| 1524047096162.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047121857.00 | 3 |
| 1524047097163.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047122868.00 | 3 |
| 1524047098163.00 | Channel2.ARK CNC Machine.General Status Information.Auto Operate | TRUE | 1524047123886.00 | 3 |
few rows are coming with value 0 and then 3 and again 0 respectively....
I want to calculate summasation of timestamp with intervals which has value 3
is there any way to calculate such values or can you give me any idea so that i can try?
Vikas
Filter with value 3. and iterate the infotable or do aggregation based on requirements.
Hi Satish,
Can you help to do "Filter with value 3. and iterate the infotable or do aggregation"?
I am really new to Thingworx, can you plz?
Vikas
Hi Jeff,
Here is an example per the test data you provided and it works on my Thingworx 7.0.0-b479:
var params = {
columnMappings: "Tagname;Description" /* STRING */,
fieldDelimiter: "," /* STRING */,
stringDelimiter: "\"" /* STRING */,
content: "XV101,Valve Input\n" /* STRING */,
Hope this helps,
Br,
Anna
Thanks both of you!!!! My issue was the space between the columnMappings... I appreciate it.
