Jun 1, 2021 11:20 AM UTC
Can Google Single sign-on can be implemented with ThingWorx application as SSO ?
If it is possible then anyone can explain the process or architecture. In this, in place of ping federate google single sign-on  as to be used. PTC gave full documentation of ping federate as SSO. But can google single sign-on can also be used for PTC products.
22-Sapphire I
Jun 1, 2021 12:48 PM UTC
You probably would use Ping Federate as the broker while you use Google as your IDM
https://support.pingidentity.com/s/marketplace-integration/a7i1W000000ChIUQA0/pingfederate-google-authenticator-integration-kit
Also if you are moving to the latest ThingWorx release, Ping Federate will still be available, but I believe you will be able to do SSO native to ThingWorx vs. needing to leverage Ping Federate.
Jun 7, 2021 6:49 AM UTC
So both Google workspace (as identity provider) and pingfederate is needed for SSO implementation to thingworx platform or can it be done only with Google workspace Single Sign-On (SSO). Please give me clarity on this. Actually for example, if signed in with our gmail accounts credentials then thingworx application can be signed in .
22-Sapphire I
Jun 7, 2021 1:03 PM UTC
Correct.
As far as any additional clarity, what specifically are you wondering about?
Support
Jun 17, 2021 3:02 PM UTC
Hi @Raja_Redeem.
From a check of the Ping Federate website, this appears to be doable.  You will need to check the Ping Federate website for the available options.
--Sharon
Support
Jun 25, 2021 2:08 PM UTC
Hi @Raja_Redeem
If you found any of the previous responses helpful, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
