Hello
I have allocate 6G RAM to the Docker daemon and share the driver C, but it occurs problem still
int the attachments is my install logs file
How to fix this?
Thanks and Regards,
CCi_9
I had knowed what happen to it, I shuold close the firewall when I install it, and I should close and restart the docker after setting up.
Thanks for you help.
Best Regards,
CCi_9
Hi
Could you indicate:
- what is the version of docker you are using ?
- what is the version of ThingWorx Analytics Trial edition you are using ... just give us the exact complete name of the installer exe file you execute.
- what OS is this ?
Thank you
Christophe
I'm sorry to reply to you so late.
- the docker version is 17.09.0-ce-win32 (downloaded from the official website)
-the version of ThingWorx Analytics Trial edition is AnalyticsTrialEdition-8.2.0-r3-windows-installer.
-OS is win10
Thanks a lot.
Hi
thank you for this.
Could you also send the set.txt file created by the following command executed in a Command Prompt
set > set.txt
Thank you
Christophe
thanks for your help
this is the file.
Thank you
CCi_9
Hi
Could you please upload all the install log file, not just the APIRouter one ?
Christophe
Best Regards,
CCi_9
