The default localization table , like zh-cn cannot assign project. I have to export it separately after exporting the source code by project.
So I create a customized localization table called zh , but it's tokens cannot be imported although the tokens really get exported in the xml file . Is this a know problem ?
ThingWorx version : 8.5.5
Sean
Hi @seanccc.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
