Hi ,
lately I have not been able to see Maps in my Mashups and see errors as
Hi @VikasTripathi.
Which version of ThingWorx are you running and which version of the Google Maps widget have you imported? Depending on the version of ThingWorx you may want to consider upgrading to the latest Google Maps widget (3.0.3). The configuration has changed for that version, so please check the documentation.
--Sharon
Hi @VikasTripathi.
--Sharon
We are using ThingWorx 7.3.1 with GogleExtension Package 1.1.5.
If we upgrade the extension to Google Maps Widget 3.0.1 which is compatible with the TW 7.3.1 , will the existing functionalities of the mashups get affected. ?
Hi @VikasTripathi.
We recommend that you test it in a non-prod system. ThingWorx 7.3.1 is no longer supported so we would not be able to test it here.
--Sharon
Hi @VikasTripathi.
Even though the response to your question may not have been what you were hoping for, if you feel your question has been answered satisfactorily, please mark the appropriate response as the Accepted Solution for the benefit of others on the community.
--Sharon
