Collection widget top and bottom margins
jensc
I have a collection widget with a few mashups in it;
But as you can see, for whatever reason the mashups start in the middle of the container.
If I use the advanced size settings;
And set the growth ratio to 0, the collection widget itself disappears.
Is it even possible to have it start in the top left corner?
I assume it might be possible using CSS, but I would rather avoid using it.
Jens
Sorry for the vague response here but you will need to work with the properties of the collection widget and not the mashup layout.  There are  a lot of properties that will affect the layout and will take a bit of trial and error.  Assuming you collection layout is set to flow, take a look FlowLayoutXXXX dropdowns.
Travis
Travis
It seems like it was the FlowLayoutContentGravity that decided on where in the collection widget the row is, top, center or bottom.
Jens
