Communication WebServer
Gmachado14
I have an webServer in flask and I want to send some values from ThingWorx to the webServer. What is the best way? Is this possible?
Best Regards!
supandey
(To:Gmachado14)
Hi @Gmachado14 could you please elaborate a bit on the use case. Generically speaking you should be able to communicate to ThingWorx via the ThingWorx's REST API.
Gmachado14
(To:supandey)
Yes, sorry for the short description.
I am receiving data from sensors in Thingworx.
But now I want that my Things in Thingworx to communicate with a web server that I have (send a http post to the webserver).
After the first post I found the snippet (PostText) and I think that I need to use this.
Hope this new information helps
Best Regards!
supandey
(To:Gmachado14)
Hi @Gmachado14 sorry it took me sometime to get back to this. But yeah like previously mentioned and also what you found these services can help you send data via REST calls.
Additionally, if you need to write your custom REST calls using ThingWorx REST API you can always refer to this documentation for more detail ThingWorx REST API
Hope this helps.
