The Service(has datashape to) is binded to the Advanced Gird and can see the data in the Advance Grid, but when pressed on the Configure Grid Columns, it Says "Must be bound to data", not able to configure the columns
Thingworx version is 9.2
@paic @slangley @c_lowy
Shashi.
This issue is due to the permission issues, proper permission should be given to the Mashup you are using, such that Gird Columns can be Configured. That's the reason, was not able to edit them after proper bindings and using Datashape because of the Permissions.
Shashi
Please double check that the data shape is defined in the output for the service returning the data. If the data shape is not defined here you can not configure the advanced grid columns.
Travis
Hi @TravisPickett ,
Double Checked, the DataShape is present and the data can be seen in the Advance Grid, but not able to configure the Grid columns as shown in the picture !!
Shashi.
Hi @pshashipreetham,
One additional thing to check that I can think of without Tech Support getting involved is that if the binding of the result of the service to the advanced grid was done before the service had the data shape defined:
Another test you can do to validate the data shape is being returned is to add a dropdown widget. Bind your result to this widget and if you look under properties for display and value you should see the data shape labels here.
Travis
Hi @TravisPickett ,
This is not a Binding issues, as per the observation it is due to the permissions to the Mashup. Not able to find out perfect solution for the issue and the cause too.
Shashi Preetham.
Hi @pshashipreetham.
If you feel the previous responses were helpful, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
Is it possible that you are populating the grid dynamically at runtime? If you need to configure grid columns, you may have to change your design. For example, you may have to create an infotable for loading your data before populating the grid. This page from the Help Center may also provide another solution.
--Sharon
Shashi
