I see that GirdAdvanced is now a Legacy widget in the TWX 9.4, it is replaced by ptcs-grid, but when I Exclude the Column Name in ptcs-grid, those are not excluded on the Runtime, why ? is there any configuration that needs to be done?
This was a simple issue, and those columns are due to a few issues
Hi、I checked with ThingWorx 9.3 and I can to remove column names in ptcs-grid and it is not displayed in Runtime. Could you please let us know which version you are using? I thinkTWX 9.4 is not released yet
