Create Dataset fails
skef
11-Garnet
the following error is occurring, when I try to create a new Dataset with analytics v. 8.3.040507:
Execution error in service script [CreateDatasetAMS] :: Error returned from service [500]: Unexpected error occurred:Unable to parse queuedStartDateTime: 2018-10-23T11:50:15.174Z]
How can I fix this error?
skef
11-Garnet
(To:skef)
The error was caused by sufficient folder permission. The related error message was logged in the /opt/twxanalytics/data/logs/data.log
9 REPLIES 9
pshubham
8-Gravel
(To:skef)
I will be assisting you with this.
Can you please check if the zookeeper is in the running state or paused state?
Best regards,
Prakhar Shubham
skef
11-Garnet
(To:pshubham)
thanks for your fast reply. How can I check this?
pshubham
8-Gravel
(To:skef)
Can you please provide below information:
  1. Are you using a VM or native installation?
  2. What operating system are you using?
Best Regards,
Prakhar Shubham
skef
11-Garnet
(To:pshubham)
I am using a native installation, on a Linux machine
skef
11-Garnet
(To:skef)
I think zookeeper is running, since the analytics things (DataThing, ResultThing etc) are running and
ps aux | grep zookeeper
tells me, that there is a java process running which is related to zookeeper
pshubham
8-Gravel
(To:skef)
You can try running the below command and see if zookeeper process is running or not:
sudo /opt/ThingworxAnalyticsServer/bin/twas.sh list
OR
sudo /opt/ThingworxAnalyticsServer/bin/twas.sh status
Kindly adjust the path according to your installation path.
Best regards,
Prakhar Shubham
skef
11-Garnet
(To:pshubham)
The service twas-zookeeper is not running / fails to start...
# service twas-zookeeper status
● twas-zookeeper.service - ThingWorx Analytics - Zookeeper
Loaded: loaded (/etc/systemd/system/twas-zookeeper.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Mi 2018-10-24 08:06:05 CEST; 34s ago
Process: 12636 ExecStop=/opt/ThingWorxAnalyticsServer/zookeeper/bin/zkServer.sh stop (code=exited, status=0/SUCCESS)
Process: 12575 ExecStart=/opt/ThingWorxAnalyticsServer/zookeeper/bin/zkServer.sh start (code=exited, status=0/SUCCESS)
Main PID: 11504 (code=exited, status=1/FAILURE)
Okt 24 08:06:04 Laptop-036 systemd[1]: Starting ThingWorx Analytics - Zookeeper...
Okt 24 08:06:04 Laptop-036 zkServer.sh[12575]: ZooKeeper JMX enabled by default
Okt 24 08:06:04 Laptop-036 zkServer.sh[12575]: Using config: /opt/ThingWorxAnalyticsServer/zookeeper/bin/../conf/zoo.cfg
Okt 24 08:06:05 Laptop-036 zkServer.sh[12636]: ZooKeeper JMX enabled by default
Okt 24 08:06:05 Laptop-036 zkServer.sh[12636]: Using config: /opt/ThingWorxAnalyticsServer/zookeeper/bin/../conf/zoo.cfg
Okt 24 08:06:05 Laptop-036 zkServer.sh[12636]: Stopping zookeeper ... /opt/ThingWorxAnalyticsServer/zookeeper/bin/zkServer.sh: line 182: kill: (12595) - No such process
Okt 24 08:06:05 Laptop-036 systemd[1]: Started ThingWorx Analytics - Zookeeper.
skef
11-Garnet
(To:skef)
I was able start the service twas-zookeeper.
   Active: active (running) since Mi 2018-10-24 08:22:27 CEST; 20s ago
But the problem still exists. I am also getting the error message, when I try to use other twas microservices like CreateModelAMS:
[message: Execution error in service script [CreateModelAMS] :: Error returned from service [500]: Failed during training
skef
11-Garnet
(To:skef)
