Create Dataset fails
  • October 23, 2018
  • 4851 views
the following error is occurring, when I try to create a new Dataset with analytics v. 8.3.040507:
Execution error in service script [CreateDatasetAMS] :: Error returned from service [500]: Unexpected error occurred:Unable to parse queuedStartDateTime: 2018-10-23T11:50:15.174Z]
How can I fix this error?
Best answer by skef
The error was caused by sufficient folder permission. The related error message was logged in the /opt/twxanalytics/data/logs/data.log
I will be assisting you with this.
Can you please check if the zookeeper is in the running state or paused state?
Best regards,
Prakhar Shubham
skef1-VisitorAuthor
thanks for your fast reply. How can I check this?
Can you please provide below information:
  1. Are you using a VM or native installation?
  2. What operating system are you using?
Best Regards,
Prakhar Shubham
