Create Datashape with Eclipse Extension
Sathishkumar_C
Hi All,
I have created an infotable in eclipse extension and try to plot as a chart. I can able to see the data on grid by checking "ShowAllColoumns". But i can,t able to plot as chart.
How can i create a datashape with in eclipse and import into thingworx?
Thanks & Regards,
Sathishkumar C.
I saw in a widget here, and maybe you can try create a folder inside your zip file with the entities. Following the architecture:
- MyExtension.zip
  • Entities
    • DataShapes
      • You data shape.xml
  • ui
  • metadata.xml
That is the example of the xml file that defines the data shape that I found:
<?xml version="1.0" encoding="UTF-8"?>
<Entities
 build="b140"
 majorVersion="8"
 minorVersion="2"
 modelPersistenceProviderPackage="PostgresPersistenceProviderPackage"
 revision="1"
 schemaVersion="1020"
 universal="">
    <DataShapes>
        <DataShape
         baseDataShape=""
         description=""
         documentationContent=""
         homeMashup=""
         lastModifiedDate="2018-03-20T14:54:13.211+02:00"
         name="GanttChartData"
         projectName=""
         tags="Applications:GanttChart;Applications:Testing">
            <avatar></avatar>
            <DesignTimePermissions>
                <Create></Create>
                <Read></Read>
                <Update></Update>
                <Delete></Delete>
                <Metadata></Metadata>
            </DesignTimePermissions>
            <RunTimePermissions></RunTimePermissions>
            <VisibilityPermissions>
                <Visibility></Visibility>
            </VisibilityPermissions>
            <ConfigurationTables></ConfigurationTables>
            <FieldDefinitions>
                <FieldDefinition
                 baseType="NUMBER"
                 description=""
                 name="duration"
                 ordinal="8"></FieldDefinition>
                <FieldDefinition
                 baseType="DATETIME"
                 description=""
                 name="end"
                 ordinal="4"></FieldDefinition>
                <FieldDefinition
                 baseType="STRING"
                 description=""
                 name="id"
                 ordinal="1"></FieldDefinition>
                <FieldDefinition
                 baseType="STRING"
                 description=""
                 name="name"
                 ordinal="2"></FieldDefinition>
                <FieldDefinition
                 baseType="NUMBER"
                 description=""
                 name="percentage"
                 ordinal="5"></FieldDefinition>
                <FieldDefinition
                 baseType="STRING"
                 description=""
                 name="relationships"
                 ordinal="7"></FieldDefinition>
                <FieldDefinition
                 baseType="STRING"
                 description=""
                 name="resource"
                 ordinal="6"></FieldDefinition>
                <FieldDefinition
                 baseType="DATETIME"
                 description=""
                 name="start"
                 ordinal="3"></FieldDefinition>
            </FieldDefinitions>
        </DataShape>
    </DataShapes>
</Entities>
Hope it works and help.
6 REPLIES 6
Hi @Sathishkumar_C not sure if you have already tried, is this not working when you create Configuration Table? This creates the datashape fields
Thanks for your reply.
I don't know how it will work. Anyway I will try this.
Also I have defined datashape as xml in meta.xml file. It was working fine.
Thanks.
Hi @Sathishkumar_C configuration table option which i mentioned would be if you have like a configuration section in your entity.
If you are just looking to create a data shape you can invoke the EntityServices function CreateDataShape()
InfoTable myIF = new InfoTable();
FieldDefinition Field1 = new FieldDefinition("Field1", BaseTypes.INTEGER);
EntityServices es = new EntityServices();
String name = "CustomDataShape";
		String description = "Created from Extension";
		TagCollection myTag = null;
		myIF.addField(Field1);
		try {
			es.CreateDataShape(name, description, myTag, myIF);
			_logger.info("Successfully created datashape" + es.getName());
		} catch (Exception e) {
			// TODO Auto-generated catch block
			e.printStackTrace();
			_logger.error("Failed to create DS");
vxavier
(To:supandey)
I don't know if this will help, how can I create a thing that is a data shape on eclipse?
supandey
(To:vxavier)
@vxavier may be put it as part of a service in extension and then you can invoke this service on the platform to automatically create that DS entity
- MyExtension.zip
  • Entities
    • DataShapes
  • ui
  • metadata.xml
<Entities
 build="b140"
 majorVersion="8"
 minorVersion="2"
 revision="1"
 universal="">
    <DataShapes>
        <DataShape
         baseDataShape=""
         description=""
         homeMashup=""
         projectName=""
            <avatar></avatar>
                <Create></Create>
                <Read></Read>
                <Update></Update>
                <Delete></Delete>
            <FieldDefinitions>
                <FieldDefinition
                 baseType="NUMBER"
                 description=""
                 name="duration"
                <FieldDefinition
                 baseType="DATETIME"
                 description=""
                 name="end"
                <FieldDefinition
                 baseType="STRING"
                 description=""
                 name="id"
                <FieldDefinition
                 baseType="STRING"
                 description=""
                 name="name"
                <FieldDefinition
                 baseType="NUMBER"
                 description=""
                 name="percentage"
                <FieldDefinition
                 baseType="STRING"
                 description=""
                <FieldDefinition
                 baseType="STRING"
                 description=""
                 name="resource"
                <FieldDefinition
                 baseType="DATETIME"
                 description=""
                 name="start"
            </FieldDefinitions>
        </DataShape>
    </DataShapes>
</Entities>
