Custom Font
adams1
Custom Font
Is it possible to change the font for our application (globally or otherwise) in composer?
9 REPLIES 9
Aanjan
(To:adams1)
Adam, other than the standard bold, italics and underline options for fonts, I don't believe custom fonts are available natively.
Well if you dig a bit on the CSS ( css/Combined.XXXXXX.css ), you may create an extension that overrides custom fonts
Carles.
Cales~~
I couldn't understand your guide well.
Could you give a more detailed guide about applying custom font?
Our customer want to apply their custom font.
yongjune.
chichen
(To:CarlesColl)
I also need the workaround to change the font type in ThingWorx application.
Could you please explain more?
Did you look at this marketplace extension: ThingWorx IoT Marketplace
chichen
(To:CarlesColl)
Yes, I have tried it on old version ThingWorx, but it only applied on label, and it's not working on ThingWorx 7.4.
ThingWorx composer doesn’t accept font file as a image upload anymore.
Then no luck, but you are on PTC pre sales team, I think ThingWorx Labs comes from Pre sales team maybe you have resources to improve the given outdated extension...
chichen
(To:CarlesColl)
Yes, has reported the issue... but I mean, even the extension is working, it works on label only...
I am interested in the way you mentioned before.
On my original post I mean writing an extension that overrides standard TW css with your custom font, but css on TW it's a big mess an you will need to test a lot.
For instance just to give it a try I've went to Thingworx/Runtime/css/Combined.XXXX.css and changed body { font-family: } to Times New Roman and reloaded runtime and some things had changed to Times New Roman and others not, then you will need to dig around to find all font-family css and override it on your custom extension:
body { font-family: "Times New Roman" !important }
