I have created a time Series Chart using the standard widget provided in Thingworx platform. I can visually see the data correctly and have also enabled Hover, on hover I can see data which I have bound to widget, but also there is a lot of flickering when this is displayed, because of which I am not able to read the data properly.
I have also not added any auto refresh on my Mashup page.
Any idea on solving this issue would be appreciated.
has anyone else faces similar issues, and been able to resolve it?
I am experiencing the same issue on a number of chart types. Has this been resolved?
Hi @amittal-3.
What browser are you using? Are you seeing this behavior with multiple browsers?
--Sharon
It is across browser. What I found is that it occurs when the hover expands to be larger than the container it is in. I have a vertical chart in a layout widget. If the information is longer than the layout widget is wide it flickers. So I now know what causes it but not sure how to fix it.
I am using Google Chrome (Version 68.0.3440.106 (Official Build) (64-bit)). I have not tested it on other browsers.
-Aditya Mittal
