Date and time different input
SonaliPatro
7-Bedrock
 How can we provide separate date and time input in the "startDate" and "endDate" parameter of querypropertyhistory service and how specifically we can enter a different date and a different time as an input.
Please let me know the steps to implement the above scenario.
2 REPLIES 2
PaiChung
22-Sapphire I
(To:SonaliPatro)
you can probably provide some input setup for Date and for Time that you then combine using the Expression widget to make the final input.
or else have a service that takes in Date and Time and then combine that in the service before calling the service that needs a start / end
@SonaliPatro
Please check additional information here about QueryPropertyHistoryService and Expression Widget
Also, I just wanted to follow up with you to see if the previous response to your question answered the questions you had. If so, then please post it here and mark it as the Accepted Solution for the benefit of others on the community. If you are still experiencing issues, please do let us know your questions or concerns.
Vibhuti
