Dynamic panel not expanding on clicking the close button
AP_9587236
When the Collection widget is added to a dynamic panel widget, it does not fill the entire space when the panel expands or collapses. What to do for this?
slangley
(To:AP_9587236)
Hi @AP_9587236.
What version of ThingWorx are you running?  The issue may be the result of your layout.  The FlowLayout options discussed in the Help Center may provide some guidance.
--Sharon
The version is ThingWorx 9.2.3-b189. The layout options provided for collection widget is
FlowLayoutAlignment :
FlowLayoutContentGravity :
FlowLayoutGravity :
slangley
(To:slangley)
Hi @AP_9587236.
Did you try other options for adjusting your layout?  You may have to play around with it to get it the way you want it.
--Sharon
I did
slangley
(To:slangley)
Hi @AP_9587236.
Are you referring to the space that appears around the panel?  If so, you can submit a request on the ThingWorx Ideas Board.
--Sharon
