When the Collection widget is added to a dynamic panel widget, it does not fill the entire space when the panel expands or collapses. What to do for this?
Hi @AP_9587236.
What version of ThingWorx are you running? The issue may be the result of your layout. The FlowLayout options discussed in the Help Center may provide some guidance.
--Sharon
The version is ThingWorx 9.2.3-b189. The layout options provided for collection widget is
Hi @AP_9587236.
Did you try other options for adjusting your layout? You may have to play around with it to get it the way you want it.
--Sharon
I did
Hi @AP_9587236.
Are you referring to the space that appears around the panel? If so, you can submit a request on the ThingWorx Ideas Board.
--Sharon
