At every mashup change from menu I get the log above on the browser logs
I read old topics and seems was related to a google map extension, but seems not be the case (I removed also google map extension)
The pages are opened correctly, I have no errors on thingworx script or application logs
Sometimes the property name is not 'hide' but a property used on the pages, got from a data entity
It this something known ?
I have thingworx 8.5.3 cloud hosted
Hi @iguerra.
Since this is a hosted implementation, we will need to open a case for further investigation. With your approval, I'll be happy to do so on your behalf.
Regards.
--Sharon
Yes Thanks
Kind Regards
Hi @iguerra.
A case has been opened and a Support Services engineer should be reaching out shortly. I will provide the case number under private email.
Regards.
--Sharon
For others on the community, this issue has been reported to R&D and accepted as a bug. It is targeted for fix in the 9.0 release.
Regards.
--Sharon
