Hi Folks,
Is there any capability of Edge Analytics in Thingworx?
Don't want to send data from Sensor to centralized data store but perform the Analytics on the Edge itself.
I would appreciate if anybody can provide any information on Edge Analytics within/around Thingworx.
Thanks!
Hi @TanmeyTWX
It might depends on the type of analytics you are talking about.
If this is about scoring against prediction created in ThingWorx Analytics, then there should be an edge scoring capability added in release 9.0 ... subject to change though.
Kind regards
Christophe
Hi @TanmeyTWX
Kind regards
Christophe
Hi!
Is there any update on this matter? Any available documentation would be appreciated.
Nahuel
Hi @nahuel
The edge predictive service is available with release 9.0.
You can find mention of it in the Release Notes
However as indicated in the release note, this service is not available directly and you would need to contact PTC Professional Services who can assist with the implementation.
Hope this helps
Kind regards
Christophe
Hi @nahuel.
If you feel your question has now been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
Hi @slangley
I haven't initiated this thread so I cannot mark the response as the Accepted Solution.
Nahuel
Hi TanmeyTWX.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
Hi @TanmeyTWX.
Your post was answered by @cmorfin on March 2. What additional questions do you have? You will need to provide more information regarding the type of analytics you are interested in.
--Sharon
Hi @slangley,
I'm new into the Analytics and I'm currently researching on what ThingWorx on the Edge is capable of. Would you kindly point out related documentation?
An example could be training a model in ThingWorx Analytics and then deploying the trained model to the Edge so that I could reduce the amount of transmitted data.
Nahuel
Hi @slangley
I have already accepted and marked the solution. I can't see any other option to accept it again.
Thanks!
Hi @TanmeyTWX.
For some reason, this post is not appearing correctly in our monitoring tools but when I view it on the Community, I see that the solution has been selected.
Thanks for following up.
--Sharon
