Hi All,
Is there any way to create a local service that can edit thing properties like description and baseType?
I have tried :
Things[myThing][myProperty].description = newDesc;
It was worth a try but that doesn't work...
Hi Fabien,
Very close try just to it like this:
Things[myThing].description = newDesc;
and it should work
Hi Amir,
Thanks for your answer.
But reading your anwser, I realized that I wasn't very clear in my request. I'd like to modify the properties of a thing's property. So, in my example, it is the description of myProperty that I'd like to edit.
i see,
try this
Things[(Things[mything].myproperty)].description = newDesc;
Hi Fabien,
This is metadata and you need design time permissions to do it, you should look at this type of services, Things[mything] [propertyName] --> This is Runtime
Carles.
Hi Carles,
could you extend your answer? How this could be done than?
I didn't exactly did what you are required to do, but in my case I was only required to read the 'description' of property of a thing. I did by writing a script -
var params = {
name: myProperty /* STRING */
result = Things[myThing].GetPropertyDefinition(params).description
In this case if you check the output of result, its a string, displaying the text in description field.
I can suggest you to try the following (I am not sure if it would work or not)
Similar to "GetPropertyDefinition", I didn't find "SetPropertyDefinition", however there is a service, "AddPropertyDefinition" which allows you to create new property with all the new parameters as you wish, which means you can give your own description too. But there is a catch it, doesn't allow you to change the definition of any existing property, so probably you have to -
Step 1 - copy entire definition of your property for which you need to change the description (in this case, myProperty), using "GetPropertyDefinition" service
Step 2 - remove the existing property (myProperty), using "RemovePropertyDefinition" service
Step 3 - create a new property with same defination as previous, just changing to your new description using, "AddPropertyDefinition" service.
-Thanks
