Editable Grid: No empty field in grid
Kiran1
11-Garnet
I am using Editable grid to add, fetch and edit properties of a data table.
But for few properties whose values are null at present, i am not getting empty field in mashup so that i can add or edit the respective property. Instead i am getting either an empty but non-editable field or a field with 'Object object' text content. Attaching sample image.
Any solution for this please.
Thanks and Regards,
Kiran
Kiran1
11-Garnet
(To:PratJain)
Assigning default values to the property fields have solved this issue. It displays the default value when the respective field don't have any value assigned. Hope this helps.
6 REPLIES 6
PaiChung
22-Sapphire I
(To:Kiran1)
It looks as if your query is bringing back the properties as infotables or they are infotables?
Kiran1
11-Garnet
(To:PaiChung)
Yes. Query (service name: QueryDataTableEntries) brings the properties of a datatable as infotable output and is shown in grid widget.
How to get an empty field so that a value can be entered if needed?
PratJain
(To:Kiran1)
Do we have solution now?
Kiran1
11-Garnet
(To:PratJain)
slangley
(To:Kiran1)
Hi @Kiran1.
Since you have found and posted a solution to your issue, please mark your last response as the Accepted Solution for the benefit of others with similar issues.
Thank you for your participation in our community!
--Sharon
I'm having the same issue.  Did you figure out a way around this?  I wonder why the Grid displays "[object Object]" in a blank cell?
