11-Garnet
October 24, 2022
Extension Google Map
  • October 24, 2022
  • 3154 views
Hello, I have imported a modified google map widget extension but it does not appear in widgets, I have another modified google map widget extension but with another name, can it be a reason why the extension does not appear?
Hello @AC_9552412 ,
Pls check the following article for the same:
https://www.ptc.com/en/support/article/cs188314
Kindly let me know if you have any further queries.
Regards
Bhawna
11-Garnet
October 28, 2022
hello, it is not the same problem, the google map extension that I have imported does not appear in the widget box
Support
October 28, 2022
Hi @AC_9552412
This is usually a caching problem.  Try clearing your browser and restarting ThingWorx.
--Sharon
