Failed to enter ThingworxFoundation
MinNan
11-Garnet
hello
days before, i reinstall my system,from win7 to win10, both of which is 64-bit.and i am able to enter the ThingworxFoundation on win7.
after i settle all the settings, i found i can't enter ThingworxFoundation.after i reinstall the Tomcat serval times, i verify that i install Tomcat8 successfully by enter localhost:8080.
but when i put the Fadation files into their palce, and re-start Tomcat, i can't even enter Tomcat, neither at the port 8080 nor port 80.
here are some logs files in Tomcat before setting the Thingworx and after it.
Please help
Kind regards
Minnan
raluca_edu
(To:MinNan)
It seems Djava.library.path is not set:
ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ====================================================================
2018-07-23 15:06:42.968+0800 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Failed to load FlxCore library. Ensure it's in PATH (Windows) or LD_LIBRARY_PATH(other platforms) or set with the VM arg, -Djava.library.path. Error message : com.flexnet.licensing.DllEntryPoint.entry([B)I
2018-07-23 15:06:42.968+0800 [L: ERROR] [O: c.t.s.s.l.LicensingSubsystem] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ====================================================================
2018-07-23 15:06:42.968+0800 [L: WARN] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Shutting down the Platform.
Please follow solution from the following article:
ThingWorx fails to start with error "Failed to load FlxCore library"
Thank you,
Raluca
raluca_edu
(To:MinNan)
Please check the ThingworxStorage/logs/Application.log and let us know the error you see.
Thank you,
Raluca Edu
hi,Raluca Edu
here is the log fileds, i can't figure out where the problem is.
Kind regards
Minan
raluca_edu
(To:MinNan)
Thank you,
Raluca
hi,Raluca
following the article, i solved the problem.it lacks Djava.library.path in the system varibles.
but one more question is that the article reads :
  1. Remove -Djava.library.path from the Java Options field of Tomcat configuration
but the problem had not been solved before i put -Djava.library.path back to the Java Options.
please check if it is neccessary for that.
thx.
Minnan
