Google key for Map widget
rajgs
How to configure custom google key for Map widget ? Any help would be appreciated.
adam11
7-Bedrock
(To:rajgs)
Hi Raj,
You are interested in supplying your own API Key to the Google Maps widget? If so, you will need to modify the metadata.xml file (located in the GoogleWidgets_ExtensionPackage archive) to include your API key and then zip up those files again and reimport the extension.
Adam
rajgs
(To:rajgs)
Please let me know where(in which tag) in metadata.xml file should i add the Google key. Also wanted to know if by default the key added by Thingworx has any restriction on the number of locations/markers as i observe that if i add more than 140 locations Google map widget is not displayed but till 140 it displays without any error.
