We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Hi, I need support regarding connecting Android Studio to Thingworx Server.
Hi, Swapnil.
I think the place for you to start is with the ThingWorx Android SDK. There is some documentation (including example code) to be found in the ThingWorx Help Center.
Please take a look at those and see if that can help get you started off.
Thank you,
-- Craig A.
Hello!
Can you give us a bit more information about your use case? Is this in conjunction with connecting an Edge device to ThingWorx, or an Augmented Reality application to the Vuforia Experience Server?
-- Craig A.
Hi, Swapnil.
Thank you,
-- Craig A.
