Highlighting Empty rows of grid
Pallavi
I want to Highlight Empty rows of Advanced grid widget in red color.
I wrote state definition for this and give it to Row Format property of grid but it applying to all  grid rows.
Please let me know how to resolve this.
Thanks!
1 ACCEPTED SOLUTION
cmorfin
(To:Pallavi)
Hi @Pallavi
Here are 2 approach that could help:
- option1
add a new column to the grid that will be hidden for display
populate this column with a specific string (for example "empty") for the rows that are empty - this will require to write a service that scan the values before populating the grid.
Apply a state definition for the rows that have "empty" in that hidden column
-option 2
If some of the columns are of type number, define a state definition with default state being the red state for empty column, then an other state for <numeric column value>  less than <a value higher than the max possible>
Apply that state to the rowFormat property. every rows with a value will have the second state while the one with no value will get the default state.
Hope this helps
Christophe
3 REPLIES 3
cmorfin
(To:Pallavi)
Hi @Pallavi
- option1
-option 2
Hope this helps
Christophe
Pallavi
(To:cmorfin)
Hi Christophe,
Option1 is worked for me.
It will not work, only if "empty" string present in table.
So, added a column with Boolean basetype.
Thanks for the help!
Pallavi
cmorfin
(To:Pallavi)
@Pallavi
Thank you I am pleased that it was helpful.
Would you mind marking the response as correct answer as this will helps other to find the solution ?
Thank you
Kind regards
Christophe
